optimise ax3 Wireless AP
I have hAP ax3 wifi connected to a UB5009 router. My house has thick stone walls and some rooms are getting a poor signal with 20MBps from a 1GBps supply to the router, However, sitting right next to the router has 125MBps max on the 2.4 radio.
What options can I have for improving the performance of the wifi? in software and in terms of position and antennae placement. I previously used a linksys MESH w 3 boxes.
My config is below. Many thanks
2024-04-25 19:09:58 by RouterOS 7.14.2
software id = XTHN-KIHA
model = C53UiG+5HPaxD2HPaxD
serial number = HFF098RJ21S
add admin-mac=xxxxxxxxxxxxxxauto-mac=no comment=defconf name=bridge
port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac
configuration.country=“United Kingdom” .mode=ap .ssid=fa7b34m5 disabled=
no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac
configuration.country=“United Kingdom” .mode=ap .ssid=fa7b34m disabled=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=yes interface=bridge lease-time=10m
name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10
path-cost=10
set udp-timeout=10s
add interface=ether1 list=WAN
add address=192.168.88.2/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
add address=xxxxxxxxxxxxxxname=upgrade.mikrotik.com
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add disabled=yes dst-address=0.0.0.0/0 gateway=192.168.88.1 routing-table=
main suppress-hw-offload=no
add comment=“Default route” disabled=no dst-address=“” gateway=192.168.88.1
routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=
33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
