How can avoid using the 100% of the cpu?
I got 2 rb 133 with 2 r52
3.7 router os
Station → bridge
wpa2 enable
the bandwidth tool is 20 mb udp, (but i think the bottle neck is the cpu),
The 5ghz and 5ghz turbo mode shows the same performance
I disable connection tracking but i didnt see any difference
Thank you
Alex
April 10, 2008, 9:44am
2
uninstall all unneeded packages
What for?
if the packages aren’t being used then the cpu load can’t be affected
had the same problem and reached only 600kb/s
CPU was 100%
u know how i solved it??? bought 2 x RB333 . its expencive but it works great and it worth the money. THANKS MIKROTIK
magic
April 15, 2008, 6:28am
6
Use RB333 if you need more bandwidth.
disable encryption
No, the r52 do all the encryption stuff by hardware, so its the same
I tried with encryption , without it, and with compression too.
bedris
April 16, 2008, 6:07am
8
HellMind
On RB133 better use ROS 2.9x
With 2.9 i got the same benchmark result
Maybe the cpu is the bottle neck
