option 66 ROS 6.7
i have option 66 for my phones:
http://192.168.10.1:5000/provisioning
on 5.26 it works, on 6.7 i get error (attach)… to resolve my problems I need to downgrade all my router boards??
works as expected:
http://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server#DHCP_Options
you have to set ‘random text’ (note the quotes) if you want to send a string over as an option value.
when everything is set up you can check actual raw value what is going to be sent over.
i put the qoutes and now it works: ‘http://192.168.10.1:5000/provisioning
but on v 5.x it working without the quotes, the assume that phone will get url without the qoutes?
thanks
yes, there have been changes to expand on what you can do with options. So now, only HEX can be entered without anything special, but that in turn can be mixed with text and some variables.
