option 82
Anyone can help me to use the DHCP server option 82.
From the log I have seen that the relay-agent-info it’s correct, but it’s like the server isn’t able to use this information…
I have copied the relay-agent-info string inside the value field in the DHCP server → option menu but the client take an address different from what I have setted.
Suggestions?
Could you please provide some more info on your network layout?
Wouldn’t it be better to use a different IP range for the new DHCP server, and use NAT?
Are you sure there’s not another DHCP server on the same network segment?
Was anyone able to answer this question?
I am experiencing the same issue. I have set up the options with option 82 in the DHCP options tab, however it still does not seem to be returning the option82 formated replies. I see when googling this issue this morning that there is a reference to agent.circuit-id is also known as option 82, but I cannot find the values that I should be putting in there. Is anyone able to offer any suggestions
Tim
