stmx38
1
Option iCON 431
I have attached my modem to RB but i can’t see USB port under port menu.
[admin@MikroTik] > system resource usb print
# DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 1:1 RB400 OHCI 12 Mbps
2 2:3 Option N.V. Globetrotter HSUPA... 480 Mbps
[admin@MikroTik] > port print
Flags: I - inactive
# NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
[admin@MikroTik] >
ROS 4.2
sergejs
2
Install MikroTik RouterOS 4.3 version, contact support (support@mikrotik.com) with attached support-output file.
stmx38
3
sergejs
can you provide me link to instruction how to make support-output file ?
thanks
normis
4
/system sup-output
then download the file from the router file list with FTP or Winbox.
stmx38
6
sergejs
Thank you very much for adding support of my modem !
ROS v4.4
[admin@MikroTik] > /system resource usb print
1 2:3 Option N.V. Option Configuration 480 Mbps
2 1:1 RB400 OHCI 12 Mbps
[admin@MikroTik] > /port print
Flags: I - inactive
0 serial0 1 auto
1 usb5 3 9600
[admin@MikroTik] > interface ppp-client print brief
NAME MAX-MTU MAX-MRU PORT PROFILE
0 R ppp-out-Moldcell 1500 1500 usb5 default
append brief count-only detail file follow follow-only from interval where without-paging
[admin@MikroTik] > interface ppp-client print detail
0 R name=“ppp-out-Moldcell” max-mtu=1500 max-mru=1500 mrru=disabled port=usb5 data-channel=2 info-channel=2 apn=“internet”
pin=“” user=“” password=“” profile=default phone=“” dial-command=“ATDT” modem-init=“” null-modem=no
dial-on-demand=yes add-default-route=yes use-peer-dns=yes allow=pap,chap,mschap1,mschap2
[admin@MikroTik] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 D 94.139.xxx.xxx/32 10.112.112.126 0.0.0.0 ppp-out-Moldcell
