Is there any point in removing packages that I suspect I don’t need on CRS226? It has limited ram and CPU, and less running code is usually a good idea. Is there a list of what package does what for us new Mikrotik’ers?
The code are running only if you use it.
Is like uninstall internet Explorer to get pc more faster when you use firefox…
OK, so this means that it does not waste memory or waste CPU, the only waste is a tiny bit of storage on NVRAM? if No then no point in uninstalling them. Thank you!
