Oracle Database Server begin to hang and freeze
I’m new with Mikrotik when we add Mikrotik to the Environment and enable hotspot
an accountant application on Client Computers which based on Oracle Database Server
when bypassing those client from hot spot using walledgarden and ip binding the problem still exist
the only way to avoid the problem is to remove the Mikrotik from the network
Unless you provide complete router configuration export, and a rough diagram on how your network is setup it will be impossible for anyone to help you.
