Hi guys, only help to check the order of execution of the rules on the firewall.
I posted 2 photos in which the order of execution is the ones I use now and those that Mikrotik uses from default.
I believe that my rules must be reorganized for the correct execution, given that if I move the rules totally changes its operation.
Could anyone tell me if my rules must be positioned differently?
Thank you all
I dont read jpegs… and that format is particularly stressing.
/export file=anynameyouwish ( minus router serial # and any public WANP information )
When you took your exams at school, did you bring the photo of the cover of your notebook to the teacher to have them corrected?
My side it hurts LOL..
To be fair the OP may not know about exporting the config from the CLI terminal window in winbox!!!
One would think a frequent visitor would have some basic knowledge though.
Rule # 9 on case of DDoS attack, help the attacker to reboot this router for kernel failure, out of memory…
Thanks for your kindness
I wasn’t kidding, I was serious,
any rule that adds the attacking IP in the memory of the device, in case of thousands of IPs of a DDoS, completely exhausts the memory of the router…
Sorry I was not joking, since other users seem to be making fun of me, I'm not a teacher with Mikrotik, but I do my best.
Thank you for the help you give me and I'm not kidding
thank you
Since you didnt post your config as suggested I cannot help.
