Order of filter/firewall rules
Hello everybody,
I tried to set-up my first RouterOS board (a RB493AH). I was wondering in what order are router rules or bridge filter rules applied?
For example the following set of rules for the same ‘chain’:
rule 1) deny all IP traffic
rule 2) allow traffic from/to IP address x.x.x.x
rule 3) allow traffic from/to UDP port xxx
Which of the following statements applies:
  • Are they applied in order and since rule 1 matches all traffic rule 2 and 3 are ignored and thus everything (IP) is denied
  • Are they applied in order and since rule 2 is applied later traffic from ip x.x.x.x is allowed
  • Are they applied as in ‘deny over allow’ or ‘allow over deny’
Another question:
When a rule contains several properties. Are those properties AND-ed or OR-ed to be matched.
Thanls in advance
Best regards,
Xander
The rules are applied from top to bottom (If looking in Webfig / Winbox) or from lowest to highest sequence number if in the CLI. Unlike some platforms (e.g. Cisco ACLs) there is no implicit deny so if you need one (e.g. configuring a firewall) you need to add one manually.
Conditions in a rule are combined with a logical AND.
I have to add that once a rule applied, the remaining rules are not checked for the same packet.
So first hit will be applied.
Thank you very much that was really help full. Would it be helpful to add that to the wiki pages?
It could, but it is also more of a generic way of firewall rule processing.
In a quick thought about different brands, they all run first match, top to bottom.
