orignal post disappeard.....????
Hello, Im trying to configure 2 bridge 1 for wlan1 2ghz, second for 5ghz with mullvad VPN, I did found several mistakes with dns on their side and my location, spend a lot of time, wireguard works correctly with their server, but when I try to preroute traffic I get destional unreacheable, cant make network work with VPN inside.
Here is my config [ps: I can connect only threw Wifi with out cabel]
# 2023-11-11 22:57:47 by RouterOS 7.12
# software id = 04I1-9NZH
# model = D53G-5HacD2HnD
add admin-mac=DC:2C:6E:97:B8:B2 auto-mac=no comment=defconf name=bridge
add name=bridge-vpn
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" nr-band=""
/interface wireless
set [ find default-name=wlan1 ] country=thailand disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-97B8B7 \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] country=thailand disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-97B8B8 \
/interface wireguard
add listen-port=13231 mtu=1420 name=wg0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VPN-rm
/interface lte apn
set [ find default=yes ] use-peer-dns=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ip vrf
add interfaces=VPN-rm name=VPN-rm
add bridge=bridge-vpn comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
add interface=bridge-vpn list=VPN-rm
add interface=wg0 list=VPN-rm
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=146.70.199.194 endpoint-port=\
    51820 interface=wg0 persistent-keepalive=25s public-key=\
    "KB6ZA1PAixd74c+mO0VBY4j7LaitK8B4L1APbFIQyQ0="
    192.168.88.0
add address=10.65.44.7 interface=wg0 network=10.65.44.7
add address=192.168.129.1/24 interface=bridge-vpn network=192.168.129.0
    192.168.88.1
set allow-remote-requests=yes use-doh-server=\
    https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=104.16.248.249 name=cloudflare-dns.com
add address=104.16.249.249 name=cloudflare-dns.com
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=change-mss chain=postrouting new-mss=1380 out-interface=wg0 \
    passthrough=no protocol=tcp tcp-flags=syn
add action=redirect chain=dstnat dst-port=53 protocol=tcp
add action=redirect chain=dstnat dst-port=53 protocol=udp
add action=masquerade chain=srcnat out-interface=wg0
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup-only-in-table dst-address=0.0.0.0/0 interface=bridge-vpn \
    src-address=192.168.129.0/24 table=VPN-rm
add action=lookup-only-in-table dst-address=192.168.129.0/24 interface=wg0 \
    src-address=0.0.0.0/0 table=VPN-rm
/system clock
set time-zone-name=Asia/Bangkok
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
EDIT removed
sadly idk much trying to configure almost by fast setup, almost would be good if U can provide more detail info.
From now my cfg looks like this, after connection it still can ping 8.8.8.8 but by response I think connection go directly, for now I will try to work what is work by dns (1.1.1.1, 1.0.0.1)
. So you want to be able to
  • use LAN for regular traffic through local WAN (yes): 1 wifi for winbox, direct connection to network
  • use one WIFI for regular traffic through local WAN: yes
    -use one WIFI for going to MULVAD for internet??: yes
# 2023-11-11 23:55:24 by RouterOS 7.12
add name=bridge-vpn
/interface lte
/interface wireless
add name=VPN-rm
/interface lte apn
/ip hotspot profile
add name=dhcp-wg ranges=192.168.129.10-192.168.129.254
add address-pool=dhcp-wg comment=defconf interface=bridge-vpn lease-time=10m \
    name=vpnconf
    192.168.88.0
    192.168.88.1
add address=192.168.129.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=192.168.129.1
/ip dns static
    invalid
/ip firewall mangle
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
    src-address=192.168.129.0/24 table=*1
    src-address=0.0.0.0/0 table=*1
/system clock
/system note
/system ntp client
set enabled=yes
/system script
    source="\r\
    \n   } else={\r\
    \n   }\r\
    \n "
/tool mac-server
