I just tried upgrading an RB150 from 2.9.43 to 3.3. I got the following errors;
Rebooting…
Stopping services…
ERROR: installation of system-3.3 failed: broken package
ERROR: can not install advanced-tools-3.3: system-3.3 is not installed, but is required
ERROR: can not install dhcp-3.3: system-3.3 is not installed, but is required
ERROR: can not install multicast-3.3: system-3.3 is not installed, but is required
ERROR: can not install ntp-3.3: system-3.3 is not installed, but is required
ERROR: can not install ppp-3.3: system-3.3 is not installed, but is required
ERROR: can not install routerboard-3.3: system-3.3 is not installed, but is required
ERROR: can not install routing-3.3: system-3.3 is not installed, but is required
ERROR: can not install security-3.3: system-3.3 is not installed, but is required
ERROR: router installation failed!!!
Please, reinstall.
I then tried a netinstall and it failed with the following error;
RouterBOOT booter 2.6
RouterBoard miniROUTER
CPU frequency: 175 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol… OK
Got IP address: 192.168.1.10
resolved mac address 00:C0:9F:75:25:7A
transfer started … transfer ok, time=1.97s
setting up elf image… OK
jumping to kernel code
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Anyone know the next step to recover this board?
Thanks…
