OS upgrade
Hello Friends!!
I am using mikrotik RB1100AHX2. I want to upgrade the OS, here the the license shows Level 6, but the upgradable to version is not displaying. My OS is 5.25.
I have doubt, cant i upgrade the OS to 6 level.
Here i am attaching the screenshot, kindly solve my issue.
Thank you.
Yes you can upgrade to v6. Because you using factory version of software don’t show upgradable first time when you upgrade this will be show.
If you upgrade to 6.xx after that in upgradable field will be to v8.x.
Thank you for your support..
Upload this file and reboot. That will do it:
http://download2.mikrotik.com/routeros/6.7/routeros-powerpc-6.7.npk
