OS V7.8 BGP needs port 23 open
I lock down access to INPUT and found that my iBGP fails if I do not allow port 23. How come?
bgp session is on tcp 179,
maybe you either accidentally dropped it in your fw rules - or you have misconfigured somewhere else.
I have the 179 rule in and see traffic on it. The 23 rule does not have any traffic, but if I disable that rule (23) my BGP goes down. It’s very strange.
Sounds like something is there that you are not expecting. Post your config and the answer likely will reveal itself.
