Hi All,
I’m looking for best way to achieve (almost) fully redundant system. I know the solution is a bit overkill, but customer has had bad experience with existing sites. The links aren’t perfect LOS so combination of different paths and different frequencies should help.
I have 3 sites.
Site A
Site B
Site C
Site A and B are already bridged using 3rd party wireless solution controlled by another party. This is staying.
Essentially Site C needs to talk to Site A.
Plan is
Primary Dual link from C to A - 900mhz and 2.4 on 1 x RB433 AH
Primary Dual link from C to B - 900mhz and 2.4 on 1 x RB433 AH
SITE A and B are same subnet (bridged)
I’ve done DUAL OSPF successfully before for PTP but not this scenerio. Can I assume that all 4 links are going to same subnet and just configure OSPF metrics on both boards ?
Will the third party wireless bridge have any arp issues etc ? Or can we just treat it like a switch ?
Peter.
