So situation: i have several equal channels connected te my mikrotik. Other ends of channel connected to other device (not mikrotik). So i want to balance load between these channel. As i learned, i can mark packets using Random field in Mangle bookmark in Firewall section to send them to specified gateway in routing table. Question is : how will work this schema in case of channel failure?
I have two mikrotiks directly connected using to links. There is OSPF between routers and dynamic default route with two gateways. There is no nat. When i generate traffic between mikrotiks only one channel is in use. How to distribute channel load uniformly using OSPF?
