I would like to configure OSPF on my ROS VPN Server using openvpn.
The VPN Server has 7 clients (running ROS and ospf too in area 0.0.0.0).
If some client connect to the vpn server, the ospf will automatically add the interface to interface table, so it looks like this:
Flags: X - disabled, I - inactive, D - dynamic, P - passive
# INTERFACE COST PRIORITY NETWORK-TYPE AUTHENTICATION AUTHENTICATION-KEY
0 P ether1 10 1 default none
1 vpn-interconnect 10 1 default none
2 P ether2 10 1 default none
3 vpn-axfone 50 1 default none
4 D <ovpn-blava> 10 1 broadcast none
5 D <ovpn-nitra> 10 1 broadcast none
6 D <ovpn-bela> 10 1 broadcast none
7 D <ovpn-zilina> 10 1 broadcast none
8 D <ovpn-bbystrica1> 10 1 broadcast none
The problems are the virtual interfaces etc…
I can configure the cost for them using:
add interface= cost=200
The problem is when the client restarts the connection, the interface then look like this:
4 *F00009 200 1 default none
5 D <ovpn-blava> 10 1 broadcast none
6 D <ovpn-nitra> 10 1 broadcast none
8 D <ovpn-bela> 10 1 broadcast none
9 D <ovpn-bbystrica1> 10 1 broadcast none
The interface I’ve added now looks like *F00009 and new virtual interface is added with cost 10.
I would like to configure the different cost for all the ovpn clients, since there will be multiple connections from one client with different links.
Would be glad if anyone could solve my problem,
Thank you.
