OSPF and wireless AP interface not active
Hi, I have OSPF enabled on my network, and have a problem with AP that has no clients associated, OSPF route for that interface is not propagating, interface is enabled. Is this normal behaviour?
Yes, this is a normal behaviour. You have to set “disable-running-check=yes” for that interface to allow OSPF distribute the route even when no client is associated.
thank you :slight_smile:
