In our test lab, we have a CCR1009 running 6.47.9 and a RB5009 running 7.1 We are attempting an OSPF connection between the two with a PtP link. The 1009 was previously set up to talk to a test router running v6 over PtP with no issues. We replaced the v6 with the 5009, configured OSPF on the 5009 to match and no neighbors.
I can get two v7 routers to talk to each other so it is clearly an issue between v6 and v7 and my config. I am assuming v7 can create a PtP OSPF connection with a v6 router…
100.126.0.x are OSPF transit networks. 100.127.1.16 is the router loopback.
I’ve had a problem with this as well but haven’t had time to debug or do a packet capture.
Here are 10278 state changes over maybe 2 days of uptime. The router output below is from an RB4011 (ROS 7.1 testing) connected to a CCR1009 (ROS 6.48.5 long term)
[zuul@zt-gw-01.iparchitechs.net] > routing/ospf/neighbor/print detail
Flags: V - virtual; D - dynamic
0 D instance=ospf-instance-v2 area=ospf-area-0 address=100.126.10.9 router-id=100.127.0.1 state="Full" state-changes=10278 adjacency=14s timeout=36s
