Hi all,
I’ve inherited a network made up of Mikrotik routers of various models, approx 20. The network design is made up of a number of /24’s with ALL routers having an IP on one or more of the /24’s. All routes are Static. My goal is to redesign the network so that I have /30’s between my hops and a Routing Protocol in place. So to aid me I want to build a new “routed” network over the top and slowly dismantle the current /24 static network. So can you clear up a few questions I have? It’s my understanding that OSPF requires the same MTU on both facing interfaces. Also, I’m looking at one router (RT2) that actually bridges all interfaces traffic. I’ve got OSPF set up on this (RT2) and the edge router (RT1). I see the neighbor from the edge (RT1), but not the edge (RT1) as a neighbor on RT2. Could use some assistance.
Thanks so much…
Router 1
[admin@RT1] > /routing ospf instance print
Flags: X - disabled
0 name="default" router-id=10.255.255.1 distribute-default=never redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto
metric-other-ospf=auto in-filter=ospf-in out-filter=ospf-out
[admin@RT1] > /routing ospf interface print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
# INTERFACE COST PRIORITY NETWORK-TYPE AUTHENTICATION AUTHENTICATION-KEY
0 D ether2 Local 10 1 broadcast none
[admin@RT1] > /routing ospf neighbor print
0 instance=default router-id=10.255.255.2 address=10.9.0.2 interface=ether2 Local priority=1
dr-address=10.9.0.2 backup-dr-address=0.0.0.0 state="Init" state-changes=1 ls-retransmits=0
ls-requests=0 db-summaries=0
[admin@RT1] > /interface print
# NAME TYPE MTU L2MTU MAX-L2MTU
0 X vlan1 vlan 1500
1 X vlan59 vlan 1500
2 R VLAN to CS 557 vlan 1500 1594
3 R VLAN to CS 558 vlan 1500 1594
4 R VLAN to CS 556 vlan 1500 1594
5 ether10 ether 1500 1600 9116
6 ether9 ether 1500 1600 9116
7 ether7 ether 1500 1600 4080
8 ether8 ether 1500 1600 4080
9 ether6 ether 1500 1600 4080
10 ether5 ether 1500 1598 4078
11 ether4 ether 1500 1598 4078
12 ether3 ether 1500 1598 4078
13 R ether2 Local ether 1500 1500 4078
14 R ether1 Public ether 1500 1598 4078
15 R loopback bridge 1500 65535
[admin@RT1] > /ip address print
# ADDRESS NETWORK INTERFACE
28 10.9.0.1/30 10.9.0.0 ether2 Local
29 10.255.255.1/32 10.255.255.1 loopback
Router 2
admin@RT2] > /routing ospf instance print
Flags: X - disabled
0 name="default" router-id=10.255.255.2 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no
redistribute-bgp=no redistribute-other-ospf=no metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto
[admin@RT2] > /routing ospf interface print
0 D bridge1 10 1 broadcast none
[admin@RT2] > /routing ospf neighbor print
[admin@RT2] > /interface print
0 R bridge1 bridge 1500 65535
1 R ether1-BH_to_Office ether 1500
2 R ether2-BH_to_QS ether 1500
3 R ether3-BH_to_MS ether 1500
4 R ether4-57AP ether 1500
5 R ether5-24AP ether 1500
6 R ether6-Site Monitor ether 1500
7 R loopback bridge 1500 65535
[admin@RT2] > /ip address print
36 10.9.0.2/30 10.9.0.0 ether1-BH_to_Office
37 10.255.255.2/32 10.255.255.2 loopback
