Hi Everyone,
I’m running 6.44, and now attempting to turn on OSPF for route distribution between two routers. Pretty simple setup:
rb01:
- ether1: DHCP WAN
- bridge1: 172.16.42.0/24, 172.16.43.0/30, 172.27.0.0/24
- The 172.16.43.0 is being used for an IP-IP tunnel to rb02 via WAN
- Static routes are in place and working
rb02:
- ether1: DHCP WAN
- bridge1: 172.16.44.0/24, 172.16.43.0/30
- The 172.16.43.0 is being used for an IP-IP tunnel to rb01 via WAN
When I enable OSPF and add those networks, the OSPF interfaces are dynamically added and start LSAs.
The neighbor shows up right away, but as soon as that happens, the IP-IP tunnel starts flapping constantly. If I remove the networks from OSPF, the tunnel is stable again.
Right now I have kept the static routes in-place, and they’re being redistributed. I had planned to see OSPF being stable, and then start removing the static routes one-by-one.
Any idea why the OSPF adjacency would make the tunnel flap?
Thanks!
