HI!!
What would be the best approach?
CONSIDER A MUCH LARGER NETWORK, THIS IS JUST AN EXAMPLE
OPTION A: a larger AREA0 with many small stub areas.
- Advantage: I can summarize the PPPoE clients
- Disadvantages: larger AREA0
OPTION B: smaller AREA0 with larger AREA1
- Advantage: smaller AREA0
- Disadvantages:
- I can summarize the PPPoE clients but only in R2
- larger AREAX… maybe?
OPTION C: mix between A and B… or something like that… (less likely, but I still put it)
On the PPPoE servers there are hundreds of clients, so I need to summarize.
Thanks!
If you’re going to redesign, it’s better to use OSPF, MPLS and BGP together in a design like this:
- Much better scale
- Summarization without area constraints
- Putting only ptp and loopbacks into OSPF improves convergence time sigificantly
- MPLS can be used to aggregate PPPoE sessions to fewer locations
For more general information about iBGP/OSPF/MPLS (not {PPPoE specific) read this article:
https://stubarea51.net/2020/03/03/starting-a-wisp-guide-to-selecting-a-routing-architecture/
To use redundant BRAS for scale - read this article
https://stubarea51.net/2018/04/23/pppoe-high-availability-design-incorporating-multiple-access-concentratorsbras/
Excellent information, i’ll read it. Thank you!!
