Hi I just tried to configure redistribution from ospf to BGP.
It looks like 2.9 hasn’t configured ospf distance correctly. It may be 110 and I see nothing (means 0). Same situation in static and connected routes. eBGP writes “20” there.
So I can’t redistribute BGP to ospf (because my router preferes ospf routes instead of BGP).
In 2.8 the distance on ospf routes looks fine.
May I missed anything in configuration? Or another bug in 2.9 line?
You need to use inbound filters with routing-test package eg:
/routing filter chain=ospf-in set-distance=110
/ routing ospf area set backbone area-id=0.0.0.0 authentication=none prefix-list-import=ospf-in prefix-list-export=“” disabled=no
BEWARE - the last (at least 2) versions of routing-test (up to 2.9.14 so far) are very broken. wait until about 2.9.73 and it might be closer to stable.
Just now upgraded to 2.9.16 and ospf routes are still not marked by default. I’m not so brave to load routing-test this version. Can anybody fix the problem? It must be definitelly one line in the code.
I’ve found it and testing. Distance is set, but it seems like there is still no redistribution to my ospf process … Have to look more deeply into routing tables in my area …
