ospf error
hi guys, i have a strange problem on my ospf topology.
i have 3 router connected with 3 different /30 subnets i have activated ospf and i have announced the /30 network plus 1 /24 all router see their neighbors correctly and are full state but every 2 minutes i receive this error:
discarding packet: locally originated
scr address= 172.0.0.249
and
scr address= 172.0.0.242
those errors appear in all routerboard with their respectively ip addresses. the network work correctly i only receive this error and i want to understand why. my routeros ver is 5.7 and my ospf interface are all point to point.
Do you have simple queue set on the interface where ospf is running?
hi , i have 5 interfaces and 4 are enabled on simple queue with ethernet-default. then yes it is enable
no one has some advice?
If you have queues then It is a known problem and error can be ignored. It does not affect operation of OSPF.
thank you so much
