hi.
I read this doc about Dialup Design with the Dynamic IP Assignment from a Central Address Pool. I use mikrotik routers for PPPoE NAS and ROS 4.0beta4 (because there is no NSSA in 3.x) and cisco 3560 as ABR.
there is a configuration
cisco:
router ospf 7
router-id 10.176.18.1
log-adjacency-changes
area 0 authentication
area 0.0.0.5 authentication
area 0.0.0.5 nssa
network 10.176.18.0 0.0.0.7 area 0.0.0.5
and mikrotik:
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in metric-bgp=20 metric-connected=20 \
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=as-type-1 redistribute-other-ospf=no redistribute-rip=no \
redistribute-static=no router-id=10.176.18.2
/routing ospf area
add area-id=0.0.0.5 default-cost=1 disabled=no inject-summary-lsas=no instance=default name=area5 translator-role=\
translate-always type=nssa
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/routing ospf interface
add authentication=simple authentication-key=xxx authentication-key-id=1 cost=10 dead-interval=40s disabled=no \
hello-interval=10s instance-id=0 interface=uplink network-type=broadcast passive=no priority=10 \
retransmit-interval=5s transmit-delay=1s
/routing ospf network
add area=area5 disabled=no network=10.176.18.0/29
then i connect from my test computer to NAS there is no route on cisco routing table to this computer ip ![]()
maybe error in my configuration?
