x(modem)adsl range 196.231.53.118/29—[196.231.53.112/29]eth0(450g)eth1[10.0.0.1/30]—[10.0.0.2/30]eth0(433ah)
wlan1[20.0.0.1/30]-------[20.0.0.2/30]wlan1(rb800)eth1[196.231.53.113/29]
i have ospf set up hove can i get this routing correct thats in red please help
If you specify the same subnet then it is not possible to route.
But if on RB800 eth1 you set up 196.231.53.113/32 address , then traffic to 196.231.53.113 will be routed properly because more specific route will be used.
