Equis
1
Hello
I have 5 routers 192.168.10.1 ,2 , 3, 4 and 5
And the gateway 192.168.10.100
When I reboot on of the routers all the others loose thier default route, I have no idea why.
I have just added the networks to the config and on .100 distribude default route
Can anyone help?
jorj
2
What do you mean “loose their default route” ?
Doesn’t it work anymore, doesn’t reply to ping ? or it simply dissapears ?
Do you have RIP - OSPF running ?
Try putting static routes. See what happens.
Why do you need to redistribute this default route ?
As gateway is the same for all routers.
Equis
4
It was a simplifiyed example
The gateway can change
