I have a problem with OSPF I tried every possible way I have gone through a lot of articles located here but I still cannot get OSPF working. On the devices when I do a monitor it shows that is running but I cannot see any added routes or any relevant information travelling in the net.
The routing tables do not update.
I should mention this is a lab where I test routers before deployment and their capabilities.
Is ther any bug in OSPF or some kind of limitation???
I have also read the MT manual but no help in there…
Can anyone help me or has tried any step by step manual that can help the situation???
I did that and I have setup the main OSPF router properly but again no luck. Am I missing something here???
Like setting up filters and all those things???
Guys thanks for your help I got the OSPF up and running. My problem as you specified was that it was a missconfiguration about the networks each router is connected.
