Hi all,
Please HELP ME ! Help !!!
I try to configure a VRF on interface of my Mikrotik. On this router, i use iBGP between 3 router Mikrotik with no problem (i use MPLS VPLS too with no problem). But, when i try to define default routing on my VRF, failed !! Nothing packet...?....i try to ping 8.8.8 with no success.... but if i try to ping 10.254.10.1, success ??... i have static route on my Gateway 10.254.10.2 for network 172.19.6.x....
Please HELP !!! ![]()
PC--------vrf-client-------------routeur Mikrotik-------------------------Gateway internet-------internet
172.19.6.20/24 172.19.6.1 10.254.10.1 10.254.10.2/24
loopback
10.254.1.1/32
Here my config :
[admin@Core01] > export compact
nov/25/2015 10:20:07 by RouterOS 6.33
software id = E80R-X6XF
add name=Client-A
add mtu=1526 name=Client-B
add name=LoopBack
add admin-mac=E4:8D:8C:34:86:B9 auto-mac=no name=bridge-local
set [ find default-name=ether3 ] name=Trunk-versCisco3750
set [ find default-name=ether10 ] name=VRF-client3
set [ find default-name=ether4 ] name=VersCore02
set [ find default-name=ether6 ] name=VersCore03
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether5 ] name=ether5-slave-local
set [ find default-name=ether7 ] name=ether7-slave-local
set [ find default-name=ether8 ] master-port=VersCore03 name=ether8-slave-local
set [ find default-name=ether9 ] name=ether9-outside
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-3486C2
wireless-protocol=802.11
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add interface=Client-A l2mtu=1496 name=vlan505 vlan-id=505
add interface=Client-A l2mtu=1496 name=vlan506 vlan-id=506
set 3 vlan-header=add-if-missing vlan-mode=secure
set 5 default-vlan-id=506 vlan-header=always-strip vlan-mode=secure
set 11 vlan-mode=secure
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
/ipv6 pool
add name=pool-ipv6 prefix=fde4:8dba:82e1::/64 prefix-length=64
/routing bgp instance
set default router-id=10.254.1.1
/routing ospf instance
set [ find default=yes ] distribute-default=always-as-type-1 router-id=
10.254.1.1
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=sfp1
add bridge=bridge-local interface=wlan1
add bridge=Client-A interface=Trunk-versCisco3750
add bridge=Client-A interface=ether5-slave-local
add independent-learning=no ports=
ether5-slave-local,Trunk-versCisco3750,switch1-cpu switch=switch1 vlan-id=
506
add independent-learning=no ports=Trunk-versCisco3750,switch1-cpu switch=
switch1 vlan-id=820
switch1 vlan-id=821
switch1 vlan-id=822
/interface vpls bgp-vpls
add bridge=Client-A bridge-horizon=1 export-route-targets=1:1
import-route-targets=1:1 name=bgp-vpls1 route-distinguisher=1:1 site-id=2
add address=192.168.88.1/24 comment="default configuration" interface=
bridge-local network=192.168.88.0
add address=10.254.0.1/24 interface=ether7-slave-local network=10.254.0.0
add address=10.254.1.1 interface=LoopBack network=10.254.1.1
add address=172.16.15.254/24 interface=vlan506 network=172.16.15.0
add address=10.2.3.1/24 interface=VersCore03 network=10.2.3.0
add address=172.16.16.254/24 interface=vlan505 network=172.16.16.0
add address=10.2.2.1/24 interface=VersCore02 network=10.2.2.0
add address=10.254.10.1/24 interface=ether9-outside network=10.254.10.0
add address=172.19.1.1/24 interface=vlan820 network=172.19.1.0
add address=172.19.2.1/24 interface=vlan821 network=172.19.2.0
add address=172.19.3.1/24 interface=vlan822 network=172.19.3.0
add address=172.19.6.1/24 interface=VRF-client3 network=172.19.6.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no
interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes dst-address=10.254.10.2
in-interface=VRF-client3 log=yes new-routing-mark=Reseau-VRF-client3
add action=masquerade chain=srcnat log=yes out-interface=ether9-outside
add distance=1 gateway=10.254.10.2@main routing-mark=Reseau-VRF-client3
add bgp-communities="" bgp-local-pref=100 bgp-origin=igp distance=1 gateway=
10.254.10.2
/ip route vrf
add export-route-targets=6.6.6.6:666 import-route-targets=6.6.6.6:666
interfaces=VRF-client3 route-distinguisher=6.6.6.6:666 routing-mark=
Reseau-VRF-client3
/lcd
set default-screen=interfaces read-only-mode=yes time-interval=hour
touch-screen=disabled
/lcd interface pages
set 0 interfaces="sfp1,ether1-gateway,ether2-master-local,Trunk-versCisco3750,Ve
rsCore02,ether5-slave-local,VersCore03,ether7-slave-local,ether8-slave-local
,ether9-outside,VRF-client3"
/mpls ldp
set enabled=yes lsr-id=10.254.1.1 transport-address=10.254.1.1
/mpls ldp interface
add interface=VersCore02
add interface=VersCore03
/routing bgp instance vrf
add redistribute-connected=yes routing-mark=Reseau-VRF-client3
/routing bgp network
add network=172.16.16.0/24 synchronize=no
add network=10.254.0.0/24 synchronize=no
add network=172.16.15.0/24 synchronize=no
add network=10.254.10.0/24 synchronize=no
add network=172.19.1.0/24 synchronize=no
add network=172.19.2.0/24 synchronize=no
add network=172.19.3.0/24 synchronize=no
add network=172.19.6.0/24 synchronize=no
/routing bgp peer
add address-families=ip,l2vpn,vpnv4 default-originate=if-installed name=
BGP-versCore02 remote-address=10.254.1.2 remote-as=65530 ttl=default
update-source=LoopBack
BGP-versCore03 remote-address=10.254.1.3 remote-as=65530 ttl=default
/routing ospf interface
add disabled=yes interface=VersCore02 network-type=broadcast
add disabled=yes interface=VersCore03 network-type=broadcast
add network-type=broadcast
/routing ospf network
add area=backbone network=10.2.2.0/24
add area=backbone network=10.2.3.0/24
add area=backbone network=10.254.1.1/32
add area=backbone disabled=yes network=10.254.10.0/24
/routing ospf-v3 interface
add area=backbone interface=VersCore02
add area=backbone interface=VersCore03
/system clock
set time-zone-name=Europe/Paris
/system identity
set name=Core01
/system logging
add topics=mpls,!debug
add topics=ospf,debug
add topics=bgp,debug
/tool mac-server
add interface=ether2-master-local
add interface=Trunk-versCisco3750
add interface=ether5-slave-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-outside
add interface=VRF-client3
add interface=sfp1
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=sfp1
add interface=wlan1
/tool romon port
set [ find default=yes ] cost=100 forbid=no interface=all secrets=""
add cost=100 disabled=yes forbid=no interface=all secrets=""
