I have network design shown as picture below :
Is there anyone know which dynamic routing should I use so each link could be a backup each other and how to setup it?
Thanks,
Katrokk
there’s only 6 routers
good luck
Thanks for reply Cybercoder,
But I can't make it works. First I try setup just for R0, R1 & R2 as picture shown below :
I try traceroute from R1 to R2, it fails
[usl@R0] > tool traceroute 172.18.18.5
1 0.0.0.0 0ms 0ms 0ms
2 0.0.0.0 0ms 0ms 0ms
3 0.0.0.0 0ms 0ms 0ms
When i trace back from R2 to R1 it works
[usl@R2] > tool traceroute 172.18.18.254
1 172.18.18.254 2ms 2ms 2ms
So is there any configuration that i should add/change to make the network running and can backup each other ?
Thanks,
Katrokk
