hi guys,
i have a problem about some route installing in ospf as infinite cost.
to let you help me much better i’m attaching the network architecture.
all link are point-to-point ospf and are /30 network.
pppoe server redistribute with internet2 all pppoe dynamic interface installed as ext1(all ok) but when i let firewall2 join ospf area 1 all pppoe routes are seen on ospf route as infinite.the same thing happened on the other pppoe and internet1.
the strange thing is that all 2 cisco 3550 see the ospf route correctly…
let me know if i miss something important.
BR
Infinite cost can be used a s a way to clear out routes. Have a look at the LSAs and see who is originating the infinite cost entries.
thanks for reply, but i have not set the infinite cost..then i cannot understand why are installed as infinite, infact the same route is infinite on ccr and normal(cost 110) on cisco.
what i want to understand: is normal to have this inifinite route or is an error on architecture or some other bugs?
Thanks again
BR
OSPF itself can generate infinite cost entries - some transient and some permanent. Hard to say which you are seeing without more config details.
what detail you need? i can send it to you if you have the time to help me.
Thanks a lot
