Hello
I have had bit problems with Ospf getting stuck in the init state when link is lost.
If it helps anyone I a have a workaround till teh team fixe’s this problem
I set WDS on both sides (ap bridge & station wds) and add IP’s to bridge
I then put “all” under Ospf interface
With this I can disable interface and reenable and OSPF works perfect, no reboot needed!
I hope this may help someone, I was going silly with this problem
