I am running a average sized wireless network. (9 AP’s & 28 Stations). I am running OSPF across the whole WAN. It has been running fine for about a month now all of a sudden, on random links the OPSF is coming up with
state=Init
and the traffic is not routed through. The only way it can be resolved is if i reboot the remote routerboard then it works again for a few days. I am running v2.8.26 on all the boards. Any help would be appreciated.
happened to me too - seems 2.8.26 is buggy.
I have about 20 ospf MT connected routers in my network and can confirm that with 2.8.26. Previous versions run OK.
BTW do telnet 0.0.0.0 in command promt and benefit from all quagga can offer Ports are 2604 - ospf, 2605 - bgpd.
please - everyone that has encountered this problem, please make a supout.rif file at the moment the OSPF is not working, and - with a description of the problem and your network setup, please send it to support
i noticed that this happens between 2.8.26 routers.
I have a 2.8.26 box connected with 5 other MT boxes, running different versions, and ospf hungs only on one interface, this one is connected to a 2.8.26 also..
I am having the same issue with a .26 version running ospf with a cisco router. Had no problems with older version, now it only goes to init on the cisco side and init on routeros side.
Update, it looks like the routeros is not seeing its own router id in the hellos being send back from the other router.
So its not getting past the init state.
We have this problem, but not so often ( once in a month or two months). You can write a sript tat checks route table ,and if ts too short, do a reboot. Ops, we use 2.8.19, and as I see we won’t upgrade till 2.9.
I’m talking about a community wireless network with more than 40 MT routers, everyone has 2-5 wireless interfaces (running ospf)..
and 250+ users…
Since this is a closed network, without internet access, every file transfer occurs between users..
Our main routers has 12-15Mbps traffic in EACH interface…
