HI ALL!
sorry for bad english ![]()
I have installed MK 2.9.38 on 4 computers, set wlans to AP-Bridge, set wds from each computer to other
(3WDS on each computer) set IP address on wds connections, run OSPF!
eth-> AP1---AP2
AP3 AP4-> wlan 2 - > client(nootebok)
OSPF - works! When i disable any wds on AP1 the route automatic change to other APx
but i can’t enable load balancing … traffic will go only on wds with smaller metric (maybe ??)
please help me
thanks ![]()
settings on each AP
[admin@Athlon] routing ospf> print
router-id: 0.0.0.1 (AP2 0.0.0.2, AP3 0.0.0.3 AP4 0.0.0.4)
distribute-default: never
redistribute-connected: as-type-2
redistribute-static: no
redistribute-rip: no
redistribute-bgp: no
metric-default: 0
metric-connected: 20
metric-static: 20
metric-rip: 20
metric-bgp: 20
[admin@Athlon] routing ospf area> print
Flags: X - disabled
NAME AREA-ID TYPE DEFAULT-COST AUTHENTICATION
0 backbone 0.0.0.0 default none
1 area1 0.0.0.1 default 1 none
[admin@Athlon] routing ospf network> print
NETWORK AREA
0 192.168.0.0/16 area1
