OSPF loopback problem
I’m deploying OSPF on my small network here, the problem is that whenever an interface goes down (AP reboot) OSPF and its routes also goes down, I made a loopback interface for OSPF but the problem is still happening.
Here is config exports from Tiks at two sites I’m testing it with, I’m temporarily using Broadcast but the same problem exists with NBMA.
I also tried without MD5 encryption.
Anyone know what’s up?
Site 1:
add address=172.16.1.14/28 disabled=no interface=vlan10_Network network=172.16.1.0
add address=172.16.1.17/28 disabled=no interface=vlan10_Network network=172.16.1.16
add address=10.1.1.1/25 disabled=no interface=vlan20_Customers network=10.1.1.0
add address=192.168.255.2/32 disabled=no interface=bridge_ospf network=192.168.255.2
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=ospf-in \
    metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
    metric-rip=20 metric-static=20 name=OSPF out-filter=ospf-out redistribute-bgp=no \
    redistribute-connected=as-type-1 redistribute-other-ospf=no redistribute-rip=no \
    redistribute-static=no router-id=192.168.255.2
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=OSPF name=backbone \
    type=default
/routing ospf interface
add authentication=md5 authentication-key=*** authentication-key-id=1 cost=10 \
    dead-interval=40s disabled=no hello-interval=10s instance-id=0 interface=\
    bridge_ospf network-type=broadcast passive=no priority=1 retransmit-interval=5s \
    transmit-delay=1s use-bfd=no
    vlan10_Network network-type=broadcast passive=no priority=1 retransmit-interval=\
    5s transmit-delay=1s use-bfd=no
/routing ospf network
add area=backbone disabled=no network=192.168.255.2/32
add area=backbone disabled=no network=172.16.1.0/28
add area=backbone disabled=no network=172.16.1.16/28
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes disabled=no \
    forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500 name=Bridge_ports1-5 \
    priority=0x8000 protocol-mode=none transmit-hold-count=6
    forward-delay=15s l2mtu=65535 max-message-age=20s mtu=1500 name=bridge_ospf \
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
    full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:32:73:F5 master-port=none mtu=\
    1500 name="eth1_toughswitch pro" speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
    full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:32:73:F6 master-port=none mtu=\
    1500 name=eth2_homeplug speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=Bridge_ports1-5 l2mtu=1516 mtu=1500 name=\
    vlan20_Customers use-service-tag=no vlan-id=20
    vlan10_Network use-service-tag=no vlan-id=10
Site 2:
add address=172.16.1.30/28 disabled=no interface=vlan10_Network network=\
    172.16.1.16
add address=172.16.1.33/28 disabled=no interface=vlan10_Network network=\
    172.16.1.32
add address=10.1.1.129/25 disabled=no interface=vlan20_Customers network=\
    10.1.1.128
add address=192.168.255.3/32 disabled=no interface=bridge_ospf network=\
    192.168.255.3
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
    ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
    metric-other-ospf=auto metric-rip=20 metric-static=20 name=OSPF \
    out-filter=ospf-out redistribute-bgp=no redistribute-connected=as-type-1 \
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
    router-id=192.168.255.3
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=OSPF name=\
    backbone type=default
add authentication=md5 authentication-key=*** authentication-key-id=1 \
    cost=10 dead-interval=40s disabled=no hello-interval=10s instance-id=0 \
    interface=bridge_ospf network-type=broadcast passive=no priority=1 \
    retransmit-interval=5s transmit-delay=1s use-bfd=no
    interface=vlan10_Network network-type=broadcast passive=no priority=1 \
add area=backbone disabled=no network=192.168.255.3/32
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500 name=\
    bridge_ports2-4 priority=0x8000 protocol-mode=none transmit-hold-count=6
    disabled=no forward-delay=15s l2mtu=65535 max-message-age=20s mtu=1500 \
    name=bridge_ospf priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
    no full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:78:5C:A7 master-port=\
    none mtu=1500 name=eth1_RocketDish speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\
    no full-duplex=yes l2mtu=1520 mac-address=D4:CA:6D:78:5C:A8 master-port=\
    none mtu=1500 name="eth2_5Ghz sector 120W" speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=bridge_ports2-4 l2mtu=1516 mtu=1500 name=\
You want the IP subnet on an interface stay in the routing table when the interface it belongs to goes down?
None of the IPs or networks leave the routing table, just OSPF routes.
As you seen in the config of Site 2, I’m using vlans on a bridge which bridges ports 1-4 because I may be using a ToughSwitch there soon.
Currently the backhaul is plugged into eth1 and the AP on eth2 and when I reboot the AP, OSPF drops even though the vlan and bridge are still running.
There is no difference when I use loopback vs no loopback.
I’m not sure what the exact topology is that you are referring to but in general, if an OSPF router cannot talk to its OSPF neighbour then yes it will end up removing routes that are dependent on that neighbour.
The lack of communication with that neighbour will also typically cause an election for DR and BDR on that segment in both broadcast and NBMA network types.
Try setting a static ‘admin’ MAC address on the bridge.
If the port that the bridge is adopting it’s MAC address from leaves the bridge (or goes down), the bridge (and all VLANs on the bridge) will adopt a MAC from a different port, causing OSPF to reset.
This can be prevented by setting admin-mac=‘some MAC’ and auto-mac=no
–Eric
That was it! OSPF now stays up all the time.
Thanks so much.
No problem, glad it worked.
–Eric
