Hello!
I have big l problem. My network using to 126 mt router and using full network to ospf routing.Ospf using p-p and + 1 backup line /mt device.
The problem ,ospf lsa database random /32 ip address route other mt device but i show the other router and not use the duplicate ip address.
Using ospf network range aggregation but disable this settings the routers.
backbone as-external 10.12.3.207 14.0.0.23 0x80000001 391
backbone as-external 10.12.3.207 99.1.1.2 0x80000979 997
LSA description:
netmask=255.255.255.255
metric=20
gateway=0.0.0.0
route-tag=0x0
metric=20
gateway=0.0.0.0
route-tag=0x0
Change other router, mt version(v3-4),routing test package the problem come back random again.
I attached picture the problem.
router-id: x.x.x.x
distribute-default: never
redistribute-connected: as-type-1
redistribute-static: as-type-1
redistribute-rip: no
redistribute-bgp: no
metric-default: 1
metric-connected: 20
metric-static: 20
metric-rip: 20
metric-bgp: 20
mpls-te-area: unspecified
mpls-te-router-id: unspecified
Best Regards
Krisztian
