[OSPF] MikroTik and Huawei neighbor establishment issues
Dear MikroTik community.
I have a MikrotTik CCR and Huawei router trying to deploy an ospf scenario:
This is MikroTik ospf configuration:
/interface vlan
add interface=combo1 name=OSPF_HUAWEI vlan-id=30
add address=192.168.30.2/30 interface=OSPF_HUAWEI network=192.168.30.0
/routing ospf instance
set [ find default=yes ] name=OSPF redistribute-connected=as-type-1 router-id=192.168.30.2
/routing ospf interface
add instance-id=1 interface=OSPF_HUAWEI
/routing ospf network
add area=backbone network=192.168.30.0/30
This is Huawei configuration (ospf between two Huawei routers is successful):
ospf 1 router-id 192.168.30.1
import-route direct
opaque-capability enable
area 0.0.0.0
network 192.168.30.0 0.0.0.3
interface GigabitEthernet0/2/5.30
vlan-type dot1q 30
description OSPF_MIKROTIK
ip address 192.168.30.1 255.255.255.252
ospf cost 100
ospf enable 1 area 0.0.0.0
Both equipments have direct connectivity and ping is successful.
Thanks for your attention andl help.
Best regards.
Verify MTU, timers and network type all match
I would also disable opaque LSA capability on the Huawei router until you have the neighbor working.
Thanks for your answer.
All parameters are the same in both routers, but issue remains.
Best regards.
