hi, I would like to configure the OSPF between Mikrotik and Huawei L3 switch.
Unfortunately, I do not have any neighbors.
In the logs I see packages from huawei switch, but the entries “discarding packet: wrong instance” appear.
I have the same area-id 0.0.0.0 (default area backbone).
What else do I have to do?
Should I use the default area - backbone entry? But here I can not set the area type (nssa, stub). It is only default.
Maybe I should configure my own area with another area-id?
Hello, i have the same issue, but i’m using mikrotik in both ends. I’ve setup a service provider lab, i have ospf/mpls/bgp runing in the core and i wan to configure another instance in a VRF that connects with a client (Router MT), i have to configure the same instance id in both ends in order to get the adj working. Anyone knows why?
Hi, i managed to get it working, i changed the instance id on the ospf interface, i don’t really know what is it for, beacuse it appears not to be related with the instance created on the ospf process and it’s not a field that gets shared on the hellos messages. If i change the instance-id on the interface the ospf adjacency comes up on the Test instance
