OSPF MPLS Setup Convergence
I’m setting up a couple new CCR2004 with 3 redundant paths between them on the bench using a OSPF, BGP, MPLS, VPLS configuration. When I drop out the link carrying traffic, it takes 20 seconds for traffic to re-establish on the backup link. Is this normal convergence time, or possibly a setting I am missing. Everything seems to work otherwise.
It looks like its not an OSPF convergence issue as it is looking like with 2 seconds it is re-establing a link but that the VPLS is taking 20 seconds to begin passing traffic after getting notified of the new route.
Hello. Could you give an example of the configuration ?
Hello I have same configuration without bgp and convergence is very fast. I use ospf with bfd. Max 1 or 2 pings are lost. VPLS connected immediately.
Sent from my VOG-L29 using Tapatalk
The first thing to realize is that MIkroTik does not support MPLS Fast Reroute so you won’t get convergence at 50ms.
That said,
There are several timers to be aware of:
BGP and OSPF - Use BFD here instead of standard timers and tune it to ensure the timers aren’t too aggressive.
LDP Interface hello and hold timers - Default at 5/15 seconds You can lower these but be careful not to be too aggressive or you’ll end up with instability
After all my testing, I have another setup up on some mikrotik switches that works great, it seems like its possibly a bug with the new ccr2004. I see the vpls shows the new route within 2 seconds on the web interface, but doesn’t start passing traffic for another 20 on the vpls connection. My other setup traffic flows within 4 seconds of a route change. Has anyone actually tested VPLS on the CCR2004 hardware and how long to start passing traffic after enabling the VPLS interface?
I’m sorry if this isn’t relevant. Have you tried VPS “under load” on CCR 2004 ? If so, how much was pumped and what was the CPU load ?
I just did a quick config in some other ccr with tile processors and its the same. When ping across the bridge and VPLS interface it takes 22 seconds when a link drops or resumes. I've attched a copy of the 2 test routers configs. Changing the OSPF hello and dead timers on each interface has no effect.
Router1
jan/02/1970 00:36:56 by RouterOS 6.45.9
software id = TZ79-C80B
model = CCR1016-12G
serial number = 52A304F21297
add name=bridge1
add name=loopback protocol-mode=none
/interface vpls
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=
02:B1:03:E7:5A:52 name=vpls1 remote-peer=10.255.0.5 vpls-id=1:1
/routing bgp instance
set default router-id=10.255.0.1
/routing ospf instance
set [ find default=yes ] router-id=10.255.0.1
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=vpls1
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=
192.168.88.0
add address=10.1.1.1/30 interface=ether1 network=10.1.1.0
add address=10.1.2.1/30 interface=ether2 network=10.1.2.0
add address=10.1.3.1/30 interface=ether3 network=10.1.3.0
add address=10.255.0.1 interface=loopback network=10.255.0.1
/mpls interface
set [ find default=yes ] mpls-mtu=1530
/mpls ldp
set enabled=yes lsr-id=10.255.0.1 transport-address=10.255.0.1
/mpls ldp interface
add interface=ether1
add interface=ether2
add interface=ether3
/routing bgp peer
add name=peer1 remote-address=10.255.0.5 remote-as=65530 ttl=default
/routing ospf interface
add dead-interval=20s hello-interval=5s interface=ether1 network-type=
point-to-point
add cost=20 dead-interval=20s hello-interval=5s interface=ether2
network-type=point-to-point
add cost=30 dead-interval=20s hello-interval=5s interface=ether3
/routing ospf network
add area=backbone network=10.1.1.0/30
add area=backbone network=10.1.2.0/30
add area=backbone network=10.1.3.0/30
add area=backbone network=10.255.0.0/24
Router 2
jan/02/1970 00:33:48 by RouterOS 6.40.8
software id = TDB1-UG5Y
model = CCR1036-8G-2S+
serial number = 91A909B35591
add name=bridge1
/interface vpls
02:36:AE:8D:4E:60 name=vpls1 remote-peer=10.255.0.1 vpls-id=1:1
set default router-id=10.255.0.5
set [ find default=yes ] router-id=10.255.0.5
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add address=192.168.88.2/24 comment=defconf interface=bridge1 network=
192.168.88.0
add address=10.1.1.2/30 interface=ether1 network=10.1.1.0
add address=10.1.2.2/30 interface=ether2 network=10.1.2.0
add address=10.1.3.2/30 interface=ether3 network=10.1.3.0
add address=10.255.0.5 interface=loopback network=10.255.0.5
/mpls interface
/mpls ldp
set enabled=yes lsr-id=10.255.0.5 transport-address=10.255.0.5
/mpls ldp interface
/routing bgp peer
add name=peer1 remote-address=10.255.0.1 remote-as=65530 ttl=default
point-to-point
add dead-interval=20s hello-interval=5s interface=ether2 network-type=
point-to-point
add dead-interval=20s hello-interval=5s interface=ether3 network-type=
point-to-point
Have you tried BFD?
I did enable use BFD on each OSPF interface and BGP peer. Is there anything else to do?
Its so wierd that when I unplug the cable the VPLS interface immediately shows the new next hop but traffic takes 20 seconds afterward to begin flowing again across the VPLS connection. At the top of the VPLS interface it says “not BGP signaled”, is this correct?
I was able to solve the issue. I had to set the STP to none on the bridge that the VPLS was connected to. It was already set to none on the loopback, but apparently when the route changes it also trigger RSTP which drops the traffic. Once I disabled that it worked like a champ.
recently i have same experience just like your case.
When the route change (OSPF) the packet inside vpls was drop for about 30s.
I will try to implement your tips.
i saw that in bridge STP configuration are set to RSTP
thx
