Hi all
In CISCO devices I can make IP Host and then ping on the host not on IP ( name look-up ) .
r1(config)#hostname r1
r2(config)#hostname r2
r1(config)#ip host r2 a.b.c.d
r1#ping r2
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
i received ping from host name without use the IP for make ping
and then make look-up
r1(config)#ip ospf name-lookup
r1#show ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
r2 1 FULL/DR 00:00:31 a.b.c.d FastEthernet0/0
Neighbor is router host not router IP address ,
how can i make this configure on Mikrotik CCR 1016 ??
best regards
