OSPF NBMA
I’m having a problem with OSPF
12:01:10 route,ospf,info Database Description packet has init bit set in middle of an exchange
Station-Bridge side:
12:01:10 route,ospf,info OSPFv2 neighbor 172.17.84.217: state change from Full to Down
This is happening several times a day.
I tried changing the interface to nmba and adding the nmba neighbor on each side, and while the neighbors show up, they never exchange any routes.
Any help?
That should never happen - what version are you running?
5.5 on both sides..
Now for the weird thing… for S&G, I disabled and re-enabled the OSPF instance, and the routes propagated as expected.
Now, I can understand restarting OSPF… to a point. That point, is that the change from broadcast to nmba was made on both routers, but I only had to restart one of them.
Anyways, thanks for looking.
