OSPF neighbros stuk at 2-way, please help
I have been trying to figer out why two of the adjusent router won’t talk with each other all of sudden. it was working fine for months.
Now both are stuck at 2-way state.
I have tried removing the network and adding it. rebooting the router.
no matter what I do it just doest not communicate. it is stuck in two way state.
Can somebody please tell me how to fix this
router-id=192.168.255.26 address=10.1.253.18 priority=1 state=“2-Way” state-changes=0 ls-retransmits=0
ls-requests=0 db-summaries=0 dr-id=10.1.253.18 backup-dr-id=0.0.0.0
I need more info.
The Router-ID of router A is 192.168.255.26
To what router does 10.1.253.18 belong to? Router A or B.
But check these items out.
-Both router should have the same exact line under networks.
-Both router should be on the same subnet, and reachable to each other.
-check the OSPF Interface section, and remove all or make sure they are pointing to the right interface and Area. If you have Interface setup make sure that Authentication in both side is correct.
If nothing works, add the logging of the OSPF and look to see if you see the error that way.
Hope this helps
