ok i have two wan connections that i setted up as pppoe on both of my mikrotik routers, the one is at my work site and the other at home but what i want is if the one connection goes down the other must keep on working but it doesn’t work, both of the accounts are with the same isp and have the sam gateway and dns addresses so i don't know if that will create conflict? they are all setted up lik this router A:
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 41.132.18.1 1
1 DS 0.0.0.0/0 41.132.18.1 1
2 ADo 10.0.0.0/24 192.168.6.254 110
3 ADo 10.0.1.0/24 192.168.6.254 110
4 ADo 10.1.0.0/24 192.168.6.254 110
5 ADo 10.1.1.0/24 192.168.6.254 110
6 ADC 41.132.18.1/32 41.135.135.253 mweb2 0
7 ADo 192.168.0.0/24 192.168.6.254 110
8 ADo 192.168.1.0/24 192.168.6.254 110
9 ADC 192.168.2.0/24 192.168.2.2 ether2 0
10 ADo 192.168.3.0/24 192.168.6.254 110
11 ADC 192.168.6.0/24 192.168.6.1 ether1 0
12 ADo 192.168.8.0/24 192.168.6.254 110
13 ADo 192.168.10.0/24 192.168.6.254 110
14 ADo 192.168.11.0/24 192.168.6.254 110
15 ADo 192.168.23.0/24 192.168.6.254 110
16 ADC 192.168.70.0/24 192.168.70.1 ether3 0
17 ADo 192.168.112.0/24 192.168.6.254 110
18 ADo 192.168.113.0/24 192.168.6.254 110
19 ADo 192.168.118.0/24 192.168.6.254 110
20 ADo 192.168.161.0/24 192.168.6.254 110
router B:
2 ADo 10.0.0.0/24 192.168.113.254 110
3 ADo 10.0.1.0/24 192.168.113.254 110
4 ADo 10.1.0.0/24 192.168.113.254 110
5 ADo 10.1.1.0/24 192.168.113.254 110
6 ADC 41.132.18.1/32 41.132.173.247 mweb 0
7 ADC 192.168.0.0/24 192.168.0.2 ether2 0
8 ADo 192.168.1.0/24 192.168.113.254 110
9 ADo 192.168.2.0/24 192.168.113.254 110
10 ADo 192.168.3.0/24 192.168.113.254 110
11 ADo 192.168.6.0/24 192.168.113.254 110
12 ADo 192.168.8.0/24 192.168.113.254 110
13 ADo 192.168.10.0/24 192.168.113.254 110
14 ADo 192.168.11.0/24 192.168.113.254 110
15 ADo 192.168.23.0/24 192.168.113.254 110
16 ADo 192.168.70.0/24 192.168.113.254 110
17 ADC 192.168.112.0/24 192.168.112.1 ether3 0
18 ADC 192.168.113.0/24 192.168.113.1 ether4 0
19 ADC 192.168.118.0/24 192.168.118.1 ether1 0
20 ADo 192.168.161.0/24 192.168.113.254 110
the router a is always type 1 and the other router i made type 2 but if router a disconnect it doesn’t use router b to get to the internet aney idea?
