My 2 routers RB750 can’t talk to each other over eoip with OSPF. They are ping-able within 172.16.0.4/30 network.
# aug/11/2011 16:28:33 by RouterOS 5.6
# software id = V1RA-I9P2
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=as-type-1 \
redistribute-other-ospf=no redistribute-rip=no redistribute-static=\
as-type-1 router-id=172.17.0.1
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=\
default
/routing ospf interface
add authentication=none authentication-key="" authentication-key-id=1 \
comment="Static interface" cost=10 dead-interval=40s disabled=no \
hello-interval=10s instance-id=0 interface=BR.GW-MS-2 network-type=\
point-to-point passive=no priority=1 retransmit-interval=5s \
transmit-delay=1s use-bfd=no
/routing ospf network
add area=backbone disabled=no network=172.16.0.4/30
# aug/11/2011 16:33:48 by RouterOS 5.6
# software id = VMZ1-FWZX
as-type-1 router-id=172.16.0.2
/routing ospf area
default
comment="static interface" cost=10 dead-interval=40s disabled=no \
hello-interval=10s instance-id=1 interface=BR.GW-MS-1 network-type=\
point-to-point passive=yes priority=1 retransmit-interval=5s \
add area=backbone disabled=no network=10.0.1.0/24
This is current state of configuration after changing it long enough. Any help would be appreciated.
Thank you!
