OSPF OUT Routing Filters issue
Hi all,
I have a situation where I want to use ROS 7 OSPF filters to stop routes from being send OUT of a VPN interface but I still want to learn Routes coming IN via the VPN.
basically it should be along the lines of this: If (routes coming from VPN){accept} / IF (routes going out VPN){reject;}
I have no idea how to go about the rules and what it should be. any help if possible, im running ROS 7.12.
I goal is to just lessen the routing table so I will be adding a static block to go via the VPN instead of individual routes being learned.
Explain more about the use case
Basically I have a VPN from site A to Site B.
Site A must distribute routes to site B but Site B must not Distribute to Site A. (I instead will use a static route for a signle big block to route the missing routes once they have been blocked.)
Above - forgot to quote your reply. :slight_smile:
got it working.
This is the filter rule I used.
add chain=ospf-in comment=Middle disabled=no rule=“if (gw in x.x.x.x){reject}”
Where x.x.x.x is the IP address of the said interface.
