I need a dynamic solution to distribute routes through IP-tunnels of connected clients.
Here one scenario:
3 routers A B and C with static routes. A connected with B. B connected with C.
There is an IP-tunnel from A to C. PPPoE-client is connecting with IP 172.28.0.1 to A.
How to distribute the IP of the PPPoE-client through the IP tunnel so that C knows that packets to 172.28.0.1 have to be routed through the IP tunnel?
(C should not route the packets to router B and then to A.)
Is there a solution with OSPF or with an other routing protocol? How to setup?
Regards
Tom
