Good afternoon. I have a problem with the availability of my router. scheme:
All routers are configured with OSPF (backbone area ). The interface R(XN) looking at R2 has a weight of 60
And router R(XN) not ping R2, there is a route to R2 via R1. But R1 ping R2 not problem and vice versa.
nat not use router R1.
If change ospf interface to type broadcast, both interface router R(XN) State: designated router.
What can I be missing?
For example:
[R7] > /routing ospf interface print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
# INTERFACE COST PRIORITY NETWORK-TYPE AUTHENTICATION AUTHENTICATION-KEY
0 l2tp-R2 60 1 point-to-point none
1 DP loopback 10 1 broadcast none
2 D l2tp-R1
[R7] > /routing ospf neighbor print
0 instance=default router-id=172.16.25.2 address=172.16.26.132 interface=l2tp-R2 priority=1 dr-address=0.0.0.0 backup-dr-address=0.0.0.0 state="Full" state-changes=4 ls-retransmits=0 ls-requests=0 db-summaries=0 adjacency=1m26s
1 instance=default router-id=172.16.25.1 address=172.16.26.1 interface=l2tp-R1 priority=1 dr-address=0.0.0.0 backup-dr-address=0.0.0.0 state="Full" state-changes=4 ls-retransmits=0 ls-requests=0 db-summaries=0 adjacency=7h32m45s
[R7] > ping 172.16.25.1
SEQ HOST SIZE TTL TIME STATUS
0 172.16.25.1 56 64 548ms
1 172.16.25.1 56 64 549ms
sent=2 received=2 packet-loss=0% min-rtt=548ms avg-rtt=548ms max-rtt=549ms
[R7] > ping 172.16.25.2
0 172.16.25.2 timeout
1 172.16.25.2 timeout
2 172.16.25.2 timeout
[R7] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
4 ADo 172.16.25.1/32 172.16.26.1 110
5 ADo 172.16.25.2/32 172.16.26.1 110
R2]/ip route print
5 ADo 172.16.25.1/32 172.16.27.1 110
6 ADC 172.16.25.2/32 172.16.25.2 loopback 0
9 ADo 172.16.25.7/32 172.16.26.137 110
[R1] /ip route> print
7 ADC 172.16.25.1/32 172.16.25.1 loopback 0
8 ADo 172.16.25.2/32 172.16.27.2 110
9 ADo 172.16.25.5/32 172.16.27.2 110
11 ADo 172.16.25.7/32 172.16.26.7 110
I understood what problem
