OSPF over OPENVPN tunnels
Hi, I’m new to OSPF in Mikrotik and I’m trying to get it working over a OPENVPN site to site tunnel. For some reason, there is no interface running OSPF even when the tunnel is running correctly. Router1 (server) is running RouterOS 6.48.1 and Router2 (client) is running 6.48.2. Here is the configuration of both sides:
OPENVPN - Router 1:
/interface ovpn-server server set auth=sha1 certificate=SERVER cipher=aes256 default-profile=ovpn enabled=yes netmask=32 require-client-certificate=yes
ppp secret add local-address=10.1.1.1 name=S2S password=“********” profile=ovpn remote-address=10.1.1.2 service=ovpn
OPENVPN - Router 2:
/interface ovpn-client add certificate=cert_blabla.crt_0 cipher=aes256 connect-to=Router1 cloud mac-address=FE:66:F1:4F:59:21 name=S2S password=“****” profile=default-encryption
user=S2S
OpenVPN is working fine with static routing. Now, for OSPF:
OSPF - Router 1:
/interface bridge add name=loopback
add address=192.168.3.1/24 interface=ether5 network=192.168.3.0
add address=192.168.11.1/24 interface=ether4 network=192.168.11.0
add address=10.255.255.1 interface=loopback network=10.255.255.1
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=10.255.255.1
/routing ospf network
add area=backbone network=192.168.3.0/24
add area=backbone network=192.168.11.0/24
OSPF - Router 2:
add address=192.168.1.1/24 interface=ether5 network=192.168.1.0
add address=10.255.255.2 interface=loopback network=10.255.255.2
set [ find default=yes ] redistribute-connected=as-type-1 router-id=10.255.255.2
add area=backbone network=192.168.1.0/24
Am I missing something? Please let me know if I should give more configuration info.
Thanks in advance.
Regards
loopback address is not match with the defined OSPF networks.
