OSPF ,PIM over HOTSPOT Server
Just finished from configure a VOD system with OSPF running between Routers (( Server - Clients )),
the LAN for client Router its configured with HOTSPOT, DHCP IP,
The problem Users can see the video without authentication no password or username used while I can’t ping the gateway for local LAN (( unreachable )) and no network Action done (( need to login )) , but i can open the multicast video.
were is the wrong :confused: .
Regards.
any answer?
