OSPF-PPPoE Summarize ROS6 vs ROS7
I need to summarize the PPPoE of my clients, with RouterOS 6 with the following configuration I got that as soon as 1 PPPoE is connected, the summed range is automatically published. But in RouterOS 7, with the following configuration I get that the summed range is published, but also the PPPoE is published individually. I don’t really know how to get only the range summarized to be published.
RouterOS 6:
/routing ospf area
add area-id=0.0.0.1 default-cost=1 inject-summary-lsas=no name=pppoe type=stub
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=10.0.0.170
/routing ospf area range
add area=pppoe range=1.1.0.192/26
add area=pppoe range=1.1.0.0/26
/routing ospf interface
add network-type=broadcast passive=yes
cost=4 interface=ether7 network-type=broadcast
cost=2 interface=ether8 network-type=broadcast
/routing ospf network
add area=backbone network=10.0.0.0/16
add area=pppoe network=1.1.0.192/26
add area=pppoe network=1.1.0.0/26
Router OS 7:
add disabled=no name=ospf-instance-1 originate-default=never redistribute=connected,static,ospf,dhcp router-id=RID_OSPF routing-table=main
/routing ospf area
add disabled=no instance=ospf-instance-1 name=ospf-Backbone
add area-id=0.0.0.1 disabled=no instance=ospf-instance-1 name=pppoe type=stub
add area=pppoe disabled=no prefix=1.1.0.192/26
add area=pppoe disabled=no prefix=1.1.0.0/26
/routing ospf interface-template
add area=ospf-Backbone cost=10 disabled=no interfaces=vlan999 networks=10.0.0.0/16
add area=pppoe cost=10 disabled=no instance-id=1 interfaces=dynamic passive type=ptp
You have enabled external route redistribution in ospf instance, most likely those ppp routes are advertised as external.
I don’t have any BGP instance, or if I understood correctly mark in the OSPF instance the BGP propagation. But in that case it has no effect.
In the end, if there is another way to make the pppoe not propagate along with the other connected individually but summed up… that’s what I need.
Redistribute-connected makes PPPoE network to be considered as external.
Instead of
Try this:
add disabled=no name=ospf-instance-1 originate-default=never redistribute=static,ospf,dhcp router-id=RID_OSPF routing-table=main
add area=pppoe cost=10 disabled=no instance-id=1 prefix=1.1.0.192/26 passive type=ptp
add area=pppoe cost=10 disabled=no instance-id=1 prefix=1.1.0.0/26 passive type=ptp
Not sure if redistribute=connected is needed in your scenario. But now, I think it should fit your needs.
If I do that I stop publishing all my connected networks (whether they are interface ips, loopback ips, etc…,).
I just need it to do the same as ROS 6. That the connected IPs, in this case the pppoe, are summed up in the backbone network.
In fact this happens, but also the IP is published alone, I mean, in IP Routes in the other routers I have:
DAo 1.1.0.192/26
DAo 1.1.0.193
DAo 1.1.0.194
DAo 1.1.0.195
DAo 1.1.0.0/26
DAo 1.1.0.4
DAo 1.1.0.5
When I should have:
DAo 1.1.0.192/26
DAo 1.1.0.0/26
What I want is not to publish the /32 of the PPPoE, only the summed ones, with the config that I show in RouterOS 6 it works perfectly.
Same problem, any updates?
in the neighbord V6 you can add an routing filter to discard all 10.x.x.x/24 prefix /32 networks, it works for me
