will you add ospf process-id function in the next version of MK?
so you can define where this process-id could join an aoutonomous system
just like juniper, juniper or other that using the same method.
also.. can you deploy a feature that make native vlan can be changed beside default
vlan 1, so it could talk the trunk to layer 2 that have the native vlan feature adjustable .
i think those two are reasonable for security purposes.
kind rgds..
